Northwest Members WA, OR, ID, MT, WY, SD, ND
Autopsy results
Old Jul 15, 2007 | 08:50 AM
Ryan K's Avatar
Pathological Modifier
Default Autopsy results
Thanks Ellis for taking some time out of your day to look at my DOA transmission.
So the autopsy results indicated death by torque. The output shaft was snapped completely in two. In its death throws, the output shaft also took the very expensive forward 5 gear planetary set and the Reaction shaft.
So now comes the delima, it comes down to this:
GM 5 gear planet set $150
Reaction shaft $110
Hardened output shaft $600.00 (300M)
and I am sure there is gonna be some Misc $$$
So basically $900 to rebuild the 4L60e and then worry about it living at 800+ hp or do I go Turbo 400?
I think I can get a Th400 setup the way I want it for $1800.
I'd like a trans brake, 2.75 first gear and built with enough strength to handle the power.
As far as the converter goes, I am sure I could sell/trade my way to a good converter for the 400 for not too much extra $$$. I already have a drive shaft that may work for the th400 and 9". I would need a new shifter... But I think I could do the th400 for about $2300 ish.
So $2300 and never worry about the tranny but loose O/D or $900 and walk around with glass slippers...and keep the O/D, and Automatic shifts.
Man Being fast is expensive!
Ryan K.
Pictures coming
Old Jul 15, 2007 | 10:01 AM
Ryan K's Avatar
KrautBurner's Avatar
it will make for sux if you wanna drive it on the street much (unless you go with a gear venders overdrive)
just ask Ryan'sSS
Old Jul 15, 2007 | 10:44 AM
Ryan K's Avatar
Well Ryan'sSS was running 4.10 gears... I wouldn't even do that with a OD tranny.
Old Jul 15, 2007 | 12:08 PM
Robert56's Avatar
If it was me, I would opt for the turbo 400. Then wheel standing launches on a reg basis could be had. If I don't watch it, I'll be in the same boat, so I'll be taking it easy.
Robert
Old Jul 15, 2007 | 12:40 PM
Chris Stewart's Avatar
Break out the JB Weld, just be sure it's the heavy-duty stuff!
I had similar problem with a 5.0 . Much less power than you, but I kept busting the Automatic OD tranny and it's about 2K a pop to replace it. Tried 4 different companies before getting one that held. One mail order, and 3 different "performance" builders. That almost made me bankrupt and wanna get a new hobby!
I would try with HD parts once for the sake of keeping OD.
Old Jul 15, 2007 | 12:58 PM
OSUBraden's Avatar
Bigger and better everytime (when **** breaks) I tell you!
When I crashed my '68 stang.. I bought another one and a Z28 Camaro!
This means you buy both trannys?
Old Jul 15, 2007 | 02:27 PM
NVME's Avatar
If you're going to give up OD have you thought of going 'Glide?
Old Jul 15, 2007 | 05:06 PM
Racehead's Avatar
Is a 4L80-E physically too large to use ? Are they not capable of doing what you want ?
Old Jul 15, 2007 | 05:12 PM
Ackattack1's Avatar
I wouldn't baby around with the 4L60E. So either TH400 or 4L80E if it will fit.
Old Jul 15, 2007 | 05:31 PM
Mr.MartyStone's Avatar
I would save your money on the 2.75 first gear for a turbo car. The 4l80 will also fit but he has a 98 and the 98 pcm can't control the tranny. Would have to go with an aftermarket controller or a manual valve body, and nobody makes a brake for the 4l80 from what I have seen.
I would go Th400.
Marty
Old Jul 15, 2007 | 05:32 PM
firehawk618's Avatar
Dayyymn! I've never seen one busted like that!
Old Jul 15, 2007 | 05:35 PM
My1st Truck's Avatar
Holy cow dude, nice breakage.
Hey big poo runs a TH350 with 4.10s...Oh wait we are not talking trucks.
Why not a 4L80E? Too much money?
I would say the 400 is your best bet man! I hate breaking ****.
I don't even go out enough anymore to break.
Old Jul 15, 2007 | 07:41 PM
Ackattack1's Avatar
leaving off a trans break would be awesome!
Old Jul 15, 2007 | 08:48 PM
WAHUSKER's Avatar
Damn Ryan, that's impressive! And I thought Ellis & I were looking at an add for a hardened unit a couple weeks ago for under $400. Ellis?
Old Jul 16, 2007 | 12:07 AM
PONYEATER's Avatar
Give me a call tomorrow night I have what you need....
I will even cover getting it freshened.
Old Jul 16, 2007 | 12:23 AM
99blancoSS's Avatar
awesome damage dude!!
