Northwest Members WA, OR, ID, MT, WY, SD, ND
General 454 question
Old Aug 14, 2007 | 09:47 PM
My1st Truck's Avatar
Default General 454 question
Hey all,
I pulled my driver side exhaust manifold off of Big Poo.
89 454 TBI
I know GM had no exhaust gaskets on these, mine was ticking, I managed to get all the bolts out except the ones the hold the exhaust to the exhaust manidfold. Two of those broke, no biggie
My question is, I don't want to do this again, what kind of gasket should I used.
Also
The engine is rebuilt for GM. It says 30 over. I wonder how you compute the difference in size.
Later all.
Old Aug 14, 2007 | 09:53 PM
NWDragRacer's Avatar
Don't use a gasket. These were designed for metal-to-metal.
Old Aug 14, 2007 | 09:56 PM
So just get it machined? How do I prevent it from leaking again?
Old Aug 14, 2007 | 10:15 PM
Poik's Avatar
What about a metal gasket?
Old Aug 14, 2007 | 10:23 PM
They make copper ones. I see some guys using them. I just don't want to have to **** with it again.
I am going to have to do my RV too...
Sweet ****.
Old Aug 15, 2007 | 06:22 AM
PONYEATER's Avatar
get the manifold milled flat then bolt it on.
Old Aug 15, 2007 | 09:47 AM
Low N Slow's Avatar
I had an 89 suburban with a 454, there was a service bulletin that added a multi layer steel gasket to fix the problem. I put them in mine and never had another leak.
Old Aug 15, 2007 | 10:42 AM
XLR8N's Avatar
well to find the displacement, all you have to do is multiply. bore x pie (3.14) x stroke x number of cylinders.
now all you have to do is find the stock dimensions and add .030 to the bore.
brody
Last edited by XLR8N; Aug 15, 2007 at 10:45 AM. Reason: never attended grammar school
Old Aug 15, 2007 | 01:00 PM
Rokko's Avatar
Tech Addict
Sounds like big poo needs some longtubes.
Old Aug 15, 2007 | 01:04 PM
I thought about it, believe me, I just can't justify it. Well I can, but the wife can't...
Old Aug 15, 2007 | 01:05 PM
Hmmmm, that sounds promising!
Old Aug 15, 2007 | 02:01 PM
Rokko's Avatar
Tech Addict
I thought you wore the pants Mike......
Old Aug 15, 2007 | 04:11 PM
Depends on how much money I have spent recently on other vehicles...ahem Trans Am...
Old Aug 16, 2007 | 07:04 PM
tjwong's Avatar
You can use the new 8.1L truck engine exhaust manifold gaskets, they are like the LS1 steel shim gaskets. Machine the manifold and then use one of the gaskets between it and the block. Or you can use a FelPro exhaust header gasket.
Old Aug 16, 2007 | 08:17 PM
Well I bought a brand new manifold. I may use the 8.1 gasket. That sounds good to me.
I am not sure why GM designed it that way. I guess maybe expansion?
