Northwest Members WA, OR, ID, MT, WY, SD, ND
A.I.R. Sucks...
Old Aug 15, 2007 | 09:55 PM
My1st Truck's Avatar
Default A.I.R. Sucks...
So my manifold is cracked as well.
I finally got the A.I.R. fitting off, but the outer piece and the tubes inside the maifold are seperate pieces that compress when you screw the outer piece in. I can't get the inner pieces out and I am not sure where to get them.
What a shitty design, but what the **** do I know that is why I am not an engineer.
So I guess I will keep the AIR on the other side for now and go non-AIR on the drivers side.
Old Aug 15, 2007 | 10:09 PM
DrEvyl's Avatar
teh PuRpL3z
I'm guessing this isn't on an F-body, because it quite literally took me about 3 minutes to remove the AIR system on my Formula completely and disable it.
Old Aug 15, 2007 | 11:24 PM
No it is big poo.
Old Aug 15, 2007 | 11:39 PM
firehawk618's Avatar
Seems to be a common problem on 80's GM vehicles with AIR.
New manifolds are about $90 + s/h each.
If you need help finding them just pm me.
Old Aug 16, 2007 | 08:18 AM
Thanks many, I got one on it's way with the AIR holes welded up.
Old Aug 17, 2007 | 12:38 AM
No prob
