PS pump question
You can also search for GM Type-2 Power Steering Pump.
Since the stock pump is working at all rpm's, but it seems to work fine at say 1000 rpm, I wonder if it's generating unecessary drag at higher rpms? Maybe there is a pressure bypass valve that only lets it generate a certain amount of pressure and then reduces the load on the pump?
I don't know, I need to learn more about how the whole system works.
