Embarassing question:(
Did you try this?
Did the smoke leak out?
Electricty works on smoke. When the smoke comes out... it doesn't work.
You should connect the remote starter between the large terminal and the small terminal on the starter.
The large one is +12V from the battery and the small one activates the solenoid and turns the engine over.
Did you try this?
Did you try this?
