Northwest Members WA, OR, ID, MT, WY, SD, ND
Old Feb 16, 2008 | 01:04 PM
B-RAD2's Avatar
Default ????
Ok so will i run into any kind of problem by saudering my map wire to extend it?? Whta kind of wire whould i use??
Thanks,
Brad
Old Feb 16, 2008 | 02:35 PM
NWDragRacer's Avatar
Go to a NAPA store and get some automotive wire. Solder it and cover the joints with heat shrink tubing. Make sure you have a good mechanical connection before you solder it. Use rosin core solder for electronics and clean the flux off after it's cool. Radio shack should have the solder, heat shrink and cleaner, but DON'T use their wire.
