Northwest Members WA, OR, ID, MT, WY, SD, ND
Calculate compression ratio help
Old Mar 17, 2008 | 11:37 PM
firehawk618's Avatar
Default Calculate compression ratio help
-28cc dish piston
72cc heads
4.0" stroke
4.030" bore
not sure on headgasket thickness...
this is about all the facts I have...
I come up with about 8.3 cr
Is this close?
Old Mar 17, 2008 | 11:55 PM
KTamez's Avatar
I came up with 8.8:1 using a .030 Gasket, and assuming a zero Deck Piston Height.
http://www.rosspistons.com/calculator.php
Have Fun!
Old Mar 18, 2008 | 12:31 AM
Mr.MartyStone's Avatar
normally you'll have .005-.010 out of the hole, and with a boost motor I'd use a MLS .055" gasket. Also since you are going s/c I would shoot for around 9.5:1
Marty
Old Mar 18, 2008 | 02:19 AM
99blancoSS's Avatar
So your going s/c with the 440?
Old Mar 18, 2008 | 02:50 AM
S/c 408
Old Mar 18, 2008 | 06:49 AM
WAHUSKER's Avatar
With my -14cc pistons & similar setup plus .050 gaskets we figured 9.3 so I would think yours should be 9-ish like Kurtis posted. Sounds good for 15 psi.....
Old Mar 18, 2008 | 09:28 AM
99blancoSS's Avatar
Between you and Mark you guys are going to sound like Boeing field up there..lol
