How many guys have wet sanded
When i got my truck the plan was to wetsand the whole thing, I started by filling in rock chips, letting them cure, then starting on the whole thing.
I wetsanded all the touchups and a then went to town on the hood, it was very orangepealed. I hit the bad spots with 1500, then worked through 2500. I had a DA sander that i put some meguires pads on, tried to buff the paint out. I got close but wasnt there.
A few days later i tried again with some better compounds/technique and this is what i was left with
I am very appy with it, but i have found on the front of my hood i have some crowes feet(cracks) in the clear. I can hide them pretty well, but they still show up on occasion.(this is a sign i removed too much clear)
Altogether i had over 30 hours into it, but i had to do it twice(main reason i hav crows feet i believe)
I would recommend Meguires m105/205 to buff it out, great products, and now what i use with my Porter Cable. In the next year i plan to polish it again, ill just have to be careful on the hood(hopefully ill have a cowl hood sometime so i wont have to worry)
I would look for a (PC)Porter Cable 7424 or 7336, if your just starting out its a good way to go, it can remove what you want but wont burn through the clear.
There are lots of Videos of how to use the PC on youtube. I woud suggest lots of searches about buffing and if you have more questions keep asking.
Some products and machines can be found locally but alot of them are easier to find online.
Just thought I share a story.
My truck was "prepped" by the dealership, it was a similar story, truck looked ok for a few days then I started to see buffer trails.
Use clean stuff learn the proper technique, and take your time.
You have to remember that when wet sanding and even buffing your removing clearcoat. You don't wanna remove too much because you'll loose your UV protection of the clearcoat. You need a certain amount of mills. of build to have UV protection or else over time the clear will fade and look like it's burned and milky looking. That is why I'd never recommend a novice to buff a car.
