How to remove Camaro rear bumper ?
I already took off the Berger panel, The screws on the side by the wheels, I put the push pins up, But it is still attached to something I cant find
things required to
2 thumbscrews each to remove the taillights
2 10mm nuts hold the bumper to the truck well (pass side is behind the spare)
4 10mm nuts hold berger panel on
2 phillips screws hold bumper to fender well
4 pop fittings at top of rear bumper
2 pop fittings at bottom front corner
4 plastic push fittings across back/bottom of bumper
obviously unhook the taillights, as well as the corners as well.
Takes a little care to pull the sides out once unscrewed without marring up the car, and the bumper sits with a lip over the support beam so you have to lift it up a tad to pull it back.
