PPG Envirobase users in here
Old Jan 29, 2009 | 11:38 AM
cvalliere's Avatar
Default PPG Envirobase users in here
Well about 8 months ago my shop switched from DBC to EHP. It was a relatively smooth transition and, personally I like MUCH better than DBC. We have had some minor issues but it's more or less related to it being such a new product and it is basically being field tested by us painters, and the manufactures of gun cleaning equipment and PPG themselves are still learning.
So, I was just wondering if maybe some of you guys can post up any problems, tips, tricks, guns you prefer and tip sizes, ect.. Maybe we could all learn something form one another.
Old Jan 29, 2009 | 11:55 AM
redramair98's Avatar
out of curiosity, is this the line that is waterbased
Old Jan 29, 2009 | 12:45 PM
Fast_94_Z's Avatar
yeah thats the water based line. im not a ppg guy what so ever but i figured id check the thread out to see how people like this. from what i seen the color is normally darker in the car then when it gets sprayed out. also for water based paints i like the annest iwata guns over the sata guns but im still in a shop using solvent based so the satas are the way to go for me lol.
Old Jan 29, 2009 | 05:26 PM
BLULS1Z28's Avatar
used water based twice in r&m its ok color matched good. only tips i have been given is use a stainless gun like a iwata or stainless sata cant use a cheap gun with it. other than that i sprays like normal paint.
Old Jan 29, 2009 | 05:52 PM
RobZ's Avatar
Are these type of water based paints safer health wise?
Old Jan 29, 2009 | 09:33 PM
cvalliere's Avatar
I personally am using a Tekna non HVLP version with a 1.3 fluid tip, I've tried the Devilbiss CVI and Iwata and I liked the Tekna MUCH better. It's is a little safer but you still need to use the proper safety equipment. You can't use just any stainless gun cause most higher line guns are stainless, it's all about he grade of stainless. I have another painter I work with that was using Diamont waterbase and he liked it but the only thing he didn't like is you can't save it because it is activated. Envirobase is not activated so you can save it if it's reduced, they also have an activator that you can put in it.
Old Jan 29, 2009 | 09:48 PM
I hear eventualy its goin to be the only paint you can use
Old Jan 29, 2009 | 10:00 PM
Ricer's Avatar
badass gun... i've sold a ton of them.. and its what i use
yup.. in California and Canada it is already waterbased only... it will take another 10 years or so for it to be mandated across the country.. but a lot of shops are using it as a "go green" campaign.
Old Jan 29, 2009 | 10:06 PM
BLULS1Z28's Avatar
yeah i have heard those rumors for 5 or so years this will put alot of small shops out of business cause the curing is diffrent so need new booths and heat lamps
you work in pittsburgh? only shop i know of using full water base is wright automotive
Old Jan 29, 2009 | 10:12 PM
Ricer's Avatar
it is definitely different.. but you don't need a new booth.. a lot more airflow and some heat is needed... but i've been involved in a few retrofits.. and they weren't that bad cost-wise.
Old Jan 30, 2009 | 07:07 AM
cvalliere's Avatar
Yeah you need more air flow in the booth, it's not all about heat, you can retrofit the booths with blowers in the corners or you can get these air blowers and set them up on stands that are made for them. The talk is by 2012-2014 that it will be mandated.
This is what we have so far, there are talks about retrofitting our booths also.
http://www.anestiwata.com/products/waterbourne.cfm
Old Jan 30, 2009 | 06:46 PM
cvalliere's Avatar
Wow, nobody on here sprays this stuff? I know it's not being used a whole lot, yet. Hell the closest place I know of that is spraying this product is 2hrs. away in the Detroit area.
