High temp paint and clear
Old Feb 10, 2009 | 04:17 PM
mook99ta's Avatar
Default High temp paint and clear
Do I need a high temp clear or will regular acyrlic clear work with high temp. I am painting my valve covers so I am afraid regular clear will flake when heated up.
Thanks in advance
Old Feb 10, 2009 | 05:11 PM
nemss1's Avatar
i used all spray can high temp primer, color, and clear
just make sure to really clean the valve covers before u spray the first coat
Old Feb 10, 2009 | 05:34 PM
TransAmdriv3r's Avatar
Do yourself a favor now, just get them powdercoated...or at the very least stay away from dupicolor. I've had pretty good luck with vht but dupilcolor seems to flake for me and its not lack of prepping. I don't understand it.
Old Feb 10, 2009 | 05:41 PM
nemss1's Avatar
i used duplicolor. i made sure i cleaned the covers extremely well, sprayed 3 coats of primer, 3 coats of color, and 3 coats of clear. still looks great after 3 yrs. no fading or flaking
Old Feb 10, 2009 | 06:57 PM
i don't know what the hell im doing wrong. usually ill wire brush the part, dip it in a chemical cleaner then wipe down with alcohol. then I'll prime it, sand it down, prime it again then color and clear.
Old Feb 10, 2009 | 08:17 PM
nemss1's Avatar
i primered, let sit for 20min, primered.......and so on. 3 coats primer first (no sanding), then 3 color, then 3 clear. baked mine under a bake lamp for 20min between coats
