help with some tagging
Old Mar 9, 2009 | 01:16 AM
59 camaro's Avatar
Default help with some tagging
ok so some of u may kno im a fedex driver,well some lil kids tried to tag my truck with a sharpie marker and i just wanted to kno what would be the best way to remove the tagging?...i went to kragen and the guys there never kno ****....can anyone help?
Old Mar 9, 2009 | 01:25 AM
Pheonix's Avatar
Get some laquer thinner or rubbing alcohol. Try it out on a small spot, i am assuming you have base coat clear coat system.
Old Mar 9, 2009 | 01:40 AM
59 camaro's Avatar
thanks...ill try that
Old Mar 9, 2009 | 02:45 PM
innovative induction's Avatar
laquer thinner will dull the paint, and depending on the paint type, it may remove it! laquer thiner is a very strong thinner. I would never use it on any paint i wanted to keep. use mothers cleaner wax , or any type of cleaner wax.
it should take it right off.
Old Mar 9, 2009 | 09:59 PM
sictransit00's Avatar
Or you could try reducer, that might work
Old Mar 9, 2009 | 10:22 PM
DriftR's Avatar
On paint, laquer thinner is very aggressive, I would start with something safer like cleaner wax>clearcoat compound>white compound.
Old Mar 15, 2009 | 02:32 PM
chevrolet02z28's Avatar
Laquer thinner is a very agressive method to try at first..... That is my last resort for anything. And you need to use very little at a time... VERY LITTLE. Or you can do some damage. I've never physically seen it dull the paint.. I know applied in to much can damage it if not properly handled. A detailer i know uses it here and there.... and this guys good. just wouldn't recommend it for people who don't know how to handle it... You could also try a little bit of carburetor cleaner. Just use it sparingly as well..... BUT make sure to wax over the area after words.
use the least aggressive things first.
