Clearcoat question
Then I put high-temp primer. Then sand that down.
Then I apply the high-temp engine paint.
After a couple of hours, I apply the clear coat.
After a few hours of drying, I bolt the piece back onto the car.
This seem nice and dandy. But many, 3 days later, I'll try wipe down the piece with a microfiber towel, while tow towel doesn't do anything, if I happen to rub my finger along the piece, it leaves like, scratches in the clear coat.
If all your doing is plastic, I'd switch over to a regular Dupli-Color Lacquer paint (rattle cans are fine). They have TONS of color choices at your local auto parts store. They won't stand up to engine temps, but on the air box you won't have to worry about that.
Then follow these steps.
- scuff plastic w/ 360
- 3 coats of primer, 5-10 minutes between coats, let set 30 minutes after 3rd coat
- scuff primer with 360 (lightly)
- 3 coats of color, 5-10 minutes between coats, let set 30 minutes after 3rd coat
- 3-5 coats of clear, 5-10 minutes between coats
- let the clear set for 24 hours
- wetsand w/ 1500 - 2000 until uniformly dull / cloudy
- polish out w/ rubbing compund, working from rough cut to fine cut
- mirror finish
