Fixing Rust
Old Oct 4, 2009 | 07:27 PM
hotZ28cammed's Avatar
Default Fixing Rust
So I picked up my winter car, a little accord. It has some normal honda rust on the quater pannels. I was just seeing how I should go about fixing it. I plan on bondoing it. My plan was to first sand it with 100 grit. Then put in the bondo. Then sand about 200 grit, then move up to 500 grit. Then paint. Let me know what you guys think of this, and any writeup's or advise would be great because it is my first time doing this.
Old Oct 5, 2009 | 11:53 PM
75tonyA's Avatar
If you really like the car and plan on keeping it you are in for some work.
You could sand blast it or cut it out and weld/rivet in new metal.
Many times the rust is in between and behind the panels so it is difficult to get to so just sanding some off and covering it up will only be a temporary fix.
If it is only a winter car you might want to just leave it.
Old Oct 7, 2009 | 07:53 PM
tals7's Avatar
Smile
dont waste your time and money just leave it alone.
Old Oct 8, 2009 | 03:13 PM
BirdIsTheWord's Avatar
I wouldn't even waste my time with it, just an accord. if it breaks spend another 800$ on a car.
Old Oct 8, 2009 | 07:24 PM
Ls1Thirdgen91's Avatar
Have you considered POR 15 or RUST BULLET. RUST BULLET is amazing stuff. Just scrape away any surface rust and wirebrush it down. Then paint on the rust bullet and it will stop the rust from spreading and will convert it to a paintable surface. POR 15 is good too but RUST BULLET is a one part deal and is easier to use.
If you want it to look all pretty and stock its going to take alot tho. Like said above you will need to grind/cut/weld new pieces to fit and then go through all next steps to get it to look like factory. RUST IS A PITA to deal with. To do it right and prevent it from happening again it WILL cost more money then it will to buy a car that isnt rusted.
Old Oct 9, 2009 | 10:04 AM
97LT1's Avatar
Eastwood also has a rust converter along with a rust encapsulator.
