Headlight rubber
Old Jan 26, 2010 | 05:06 PM
jameswoodlee's Avatar
Default Headlight rubber
The rubber around my headlights is coming off. Had anyone had this same problem? I need some kind of sealant to hold the rubber on around the light where it meets the car. If so please tell me what kind you used and hwo you went about it. Like do I need to scuff up the exsisting rubber or what?
Thanks
Old Jan 26, 2010 | 08:38 PM
joesscamaro252's Avatar
I used super glue and it's holding perfectly. Just clean up the surface so you get good contact between the rubber and lens
Old Jan 28, 2010 | 08:44 AM
thanks man my ride looks bad with the rubber comign off. Do I need to scrub the rubber to scuff it up so it will hold better?
thanks
Old Jan 28, 2010 | 09:41 PM
9WhiteCamaro9's Avatar
i would get the rubber off and then clean it with like alcohol to make sure you get good contact between the rubber and the plastic on the headlight
