Learning to paint?
Old Feb 4, 2010 | 03:12 PM
Jazz-LT1's Avatar
Default Learning to paint?
I am considering painting my car, 1994 Formula myself. To be honest I have almost no experience painting, but I also had no experience building engines until I built one or honestly, watched someone build one. I would like to learn how to paint but don't have time to go to classes to learn. I know its cheaper to pay someone but its something I want to learn. I am not planning on painting the car as my first project. I also have a collection motorcycles I am restoring which most need paint also. I would start with those since its easier and the parts are smaller. I also have the original hood which I was intending to practice on as well. In the end maybe its not worth it, but its something I'd like to learn. Maybe a waste of time, I don't know.
Besides taking formal classes what's the best way to get started? I was thinking of asking around and actually paying someone to talk me thru painting the car. I think it would be worth it to get the knowledge and help - or maybe I should just forget the whole thing and have a pro paint it. It's an autocross car and not a show car so I'm not going to perfection. I'm also planning on getting a C5Z this year so I don't want to spend $3000 or more in paint work though I don't mind spending $1500 or $2000 on equipment, most of which I bet can be had used (compressor, guns, etc.)
I also just want to paint the car white, no metallics or anything like that. Just white and clear.
Old Feb 4, 2010 | 03:21 PM
collier341's Avatar
best thing would just be go out and try it. search some websites/forums. watch some videos on youtube. ask some people who work at a paint shop. then just start painting. everything. just keep doing it and it should help you get a pretty good idea of things. i recently started getting into airbrushing and have been going this route and it seems to be working alrite for me. best of luck to ya man and keep us posted on how it goes.
Old Feb 4, 2010 | 09:59 PM
Ghost666's Avatar
I agree just remember that surface prep is about the most important part of painting if you get that right it makes everything else so much easier. you can have a good paint job but if its not prepped right it will lead to nothing but problems Good Luck
Old Feb 4, 2010 | 10:17 PM
grif54's Avatar
I think you have the right idea on trying to paint. Start out with the small parts and when something doesn't turn out the way you would like(and it won't the first time) you don't have such a big job to fix. I've been restoring cars for 15 years and my first work definately wasn't the best, it just takes practice. You are definately right on about practicing. I would also maybe suggest that you get the car ready and pay someone in your area to spay the car. It will turn out clean because they will have a booth to keep all the dirt out of the paint job. Good luck and have fun.
Old Feb 5, 2010 | 07:54 AM
Jazz-LT1's Avatar
Cool. Thanks. At this point I have two vehicles that need paint, a 1994 Formula and a 1972 F100 390 C6 Shortbed, lowered 4 and 3 (no it doesn't have an LSx in it). The Formula might be do-able, but the truck is partially completed and the interior is already done in a 3 stage candy orange so not much chance of me trying that. I think my plan will be to prep the Firebird and have someone paint it, and the truck will be sprayed in yellow primer until I can afford the high dollar paint job it needs.
I do think I've come up with a good idea for my new garage however (already wife approved). The garage will have a rolling ladder that will be able to be rolled around the entire shop wall and through the corners even on a single continuous railing. I was thinking last night that the railing could also be used to hang a curtain and essentially cover all the walls of the shop with a tarp or plastic to prevent overspray. I haven't devised a very good ventilation system as yet but I'll be thinking about that as well.
So, I may never work up to painting a full car, but motorcycles would be a good start and probably what I'm more interested in painting anyway really.
Thanks again for the help. I've never been much of a body man, but I'm also not a plumber either and I spent last night redoing all the piping and pvc under my kitchen sink (wife wanted new counter tops and new sink/faucet ext.) There's something nice about doing a job yourself I guess.
Old Feb 5, 2010 | 12:27 PM
black_sheep454's Avatar
Practice makes perfect, even though a perfect paint job is impossible. Just learn as much as you can and start practicing on old parts until you think your ready to tackle you car
Old Feb 7, 2010 | 09:33 AM
omarrakeen's Avatar
I agree am learning too jst use any other car parts...start grinding painting and so on its not that hard tho but it needs work and practising...gd luck but practice well be4 u paint
Old Feb 7, 2010 | 11:31 AM
01ssreda4's Avatar
I have been friends with professional painters for a LONG time. My advice is, dont cheap out on equipment (paint guns are sacred to painters ) prep, prep, and more prep, its very labor intensive to produce good paint jobs. most dont realize this. Good luck
Old Feb 7, 2010 | 06:28 PM
FastRidesOnly's Avatar
i taught myself.
i know i'm probably doing it the ghetto way.. but i have a air compressor, gravity gun, a regulator, then a thing that catches water that hooks up beside the regulator. i just spray the prime, then i use 1stage paint. spray a tach coat then 2 more coats. then i'm done. never had a problem.. except for once where my side skirts came out too dark on my cobra. someone told me the pressure on the regulator might've caused this.
its easier to use a air sander instead of doing it by hand with a sheet of sandpaper. i always get the deep scratches out with a tough sandpaper, then i use a real smooth sandpaper with water to make it smooth... my dad told me you're suppose to sand it til its as smooth as glass.. so thats what i try to do.
but i'm still a beginner myself. although a guy at a paint shop told me he was very impressed with my first paint job. he said he was expecting the worst and and the paint came out perfect.
Old Feb 8, 2010 | 01:23 PM
dabest09's Avatar
I'm interested as well. I have a few panels on my car that need repainted.. I just don't know the process of prepping the car for paint. And that's the most important
