Fender gap from improper jacking
Old Mar 10, 2010 | 04:11 PM
1FASTZ28's Avatar
Default Fender gap from improper jacking
So I took my car to a friend of mine to get new tires put on. He didnt charge me anything to do it but when I got the car back I noticed that my fenders were pushed out got under the car and the tab the says do not jack was bent out. This isn't the first time this has happened so I once again tried moving it back and this time the piece cracked so now my fender is permanently out. Can this be fixed anyway without having to get a new fender? Can you get under there and screw the lower part of the fender under the car to the floorboards or something?
Old Mar 10, 2010 | 05:59 PM
95maroz28's Avatar
mine was like that when i got it. someone just put a screw directly underneath and it seems to be holding up
Old Mar 10, 2010 | 09:10 PM
black_sheep454's Avatar
Mine were that way and I took and bent some metal and rivited it to the fender then drilled two holes in itand put the bolts back through it
Old Mar 10, 2010 | 10:52 PM
chrysler kid's Avatar
i bought an L shaped bracket at lowes, drilled one side into the lower fender and the other onto the broken spot on the chasis
