Need Tips To Remove Doors
1. Should I unbolt the hinges from the doors leaving them attached to the jambs, or unbolt the hinges from the jambs leaving them attached to the doors? I am not near my car right now, so there may be bolts only on one end...I don't remember.
2. Again, I am not near my car right now and I can't remember, but is there a spring and if so do I need something to compress it first?
3. Will I be able to fish the wires out of the holes in the doors once I unplug the connectors from everything, or do the individual wires need to be disconnected from the plugs?
4. Any other tips or gotchas I need to look out for to make this easier?
I made it out of steel tubing but you could make a frame with 2x4s on the cheap.
You can unbolt at the door just mark it so it will go back in same spot.
Ive drilled small holes thru hinges(like 1/8") so I can easily realign.
