wetsanding vht ????
Old Sep 12, 2010 | 04:38 PM
theskitztikwon's Avatar
Default wetsanding vht ????
can i wetsand my tails after i tint them i assume i can what kind of wax compond(s) do i need and what should i start with 800 or 1000
Old Sep 12, 2010 | 06:14 PM
jimbo98z's Avatar
When I did mine and subsequently took it back off my process was:
-Paint with VHT
-2 Coats of clear
-Sit overnight
-Started sanding with 1000
-Went to 2000
-Polished with I believe Meguiars Professional Swirl Remover
-Coat of wax
Old Sep 12, 2010 | 06:31 PM
thanx ill give it a try
Old Sep 13, 2010 | 09:31 PM
Blackhawk777's Avatar
Oh yeah you can definitely wetsand. I started with 1500, moved up to 2000, then 2500. After that was a rotary with turtle wax polishing compound. glossy as if they left the factory that way.
Old Sep 13, 2010 | 09:43 PM
Black_Z28's Avatar
I did 1500 to 2000, then a rubbing compound, then a polishing compound, then wax...and you're done.
Before and after pictures.
Old Sep 14, 2010 | 10:31 AM
69lemansguy's Avatar
^^^^ holy crap! the right one looks better than my current paint on my car!
Old Sep 15, 2010 | 06:08 PM
black z28 holy **** that looks good
Old Sep 15, 2010 | 06:56 PM
WS.SIX's Avatar
That is epic... I will definately be giving my tails this treatment!!!
Old Sep 19, 2010 | 10:41 PM
Black_Z28's Avatar
The best part about doing the wet sanding is I could take care of some runs that I had, as well as a few bubbles. Now, they're basically no flaws in the paint.
Thanks for the kind words guys.
Old Sep 19, 2010 | 11:22 PM
MYSTIC-1SC's Avatar
Blackz28 what did grit paper did you use before spraying the vht on?
Old Sep 19, 2010 | 11:31 PM
Black_Z28's Avatar
Not exactly sure, I think maybe 1000. Then cleaned them with 99.8% alcohol.
Old Sep 19, 2010 | 11:33 PM
MYSTIC-1SC's Avatar
thanks.
Old Sep 20, 2010 | 03:18 PM
Black_Z28's Avatar
I went to look, and it was 700 grit sand paper. I didn't spend more then a few minutes scuffing the tail lights.
