T top to hard top conversion
Old Nov 5, 2010 | 06:00 AM
Leftoverchinese's Avatar
That's awesome!
Old Nov 5, 2010 | 11:25 AM
Jon@Texas-Speed's Avatar
Originally Posted by Jeff Smith
Why those big holes on t-top/roof? Off weight?
Yeah trying to cut out weight where I can. I don't know that it was worth it but seemed like a good idea a the time. If it ever ran a time of X.999 then the holes were worth it in my book! If it runs a x.001 I would hate myself if I didn't. haha...
Old Nov 5, 2010 | 11:32 AM
vtirocz's Avatar
Originally Posted by Jon@Texas-Speed
I just put the T-top head liner back in because it is a racecar and you can't really see it with the cage in it. It would be no big deal to put the hardtop headliner in it if you wanted.
To get the sail panel and roof off the car, I took a 18" long 3" wide flat metal and put a knife edge on it and beat it through the black silicone that has it glued on with. It takes forever going 3" at a time but I tried all kinds of other methods with zero luck! I tried all kinds of wire and nothing would cut the silicone.
As far as the bar that goes over the side window, I had a junk yard cut the entire roof off another car. Once you get the roof skin off the car, you can see the differences in the roof. I just drilled the spot welds and with a hammer and chisel peeled back the sheet metal where it overlaps and pulled that section of the roof out. You can see how it goes in from the pics above. I got the interior panels and weatherstripping with the roof from the donor car. GM has discontinued a lot of those parts so you can't get it new any longer.
Let me know if you have any other questions and I'll answer them the best I can.
Jon
Why did you have to take the sail panel off? are you welding in that location? It almost looks like you could weld the frame rails in with the sail panel still on the car.
Also, can you post progress pics that you took during this? I'm interested to do this myself, so looking to learn from your experience.
Old Nov 8, 2010 | 10:55 AM
I'm talking about taking the fiberglass cover off the sail panel. Not actually cutting the whole roof off the car. Then you get the whole fiberglass cover off the hard top car and weld in the roof supports from the hardtop in and install the fiberglass cover.
Unfortunately I didn't take any pics of the install. Just some before and after. I had it all put in at one point but ended up pulling the windshield and stuff back out of it to cut the cage out of the car again...
Jon
Old Nov 9, 2010 | 10:36 AM
vtirocz's Avatar
Jon
Could you have kept your original sail panel cover and just installed the hardtop roof skin? Or would the original sail panel cover interfere with welding the two A to B pillar frame rails?
Thanks.
Old Nov 9, 2010 | 11:21 AM
Yeah the sail panel has to come off to weld the hard top braces in the car. Also, the hardtop skin is one piece. It won't go on with the T-top sail panel on the car.
