Guide to buffing/restoring paint/clear
Old Jun 19, 2011 | 12:27 PM
LilJayV10's Avatar
Default Guide to buffing/restoring paint/clear
I remember a while back, i mean a while back, tropicare had a guide showing how to polish a car to get the swirls/scratches out. I know they have a different site now and I wasn't able to find it.
I am wanting to get the porter cable polishing kit and do my bird.
I searched for it on here but I didn't yield any good results.
Basically I'm looking for what pads I should use with what compounds. I know some are more aggressive than others.
Thanks!
Old Jun 22, 2011 | 06:33 PM
kcsov6's Avatar
I always start out with (depending on how bad the scratch is) 1000, 1500, or 2000 grit sandpaper and wetsand the area. If you start with 1000, go to 1500 next, then 2000, or if you start with 1500, go to 2000 next. You get the idea. Some people actually work up to a 3000 grit sandpaper (I can't find any in my area). Then use a wool pad to apply and buff a heavy cut compound, get a new wool pad (or clean your pad) and apply and buff medium cut cleaner. I then switch to a foam pad and apply either a swirl remover or a fine cut glaze. Then I usually use a microfiber cloth (or old shirt) to apply some Nu Finish car polish and either wipe it off with the shirt or buff it with a foam pad. Then I would wash the car with dish washing liquid (get's rid of any left over residue and shows any spots that need more work). If you see any spots that need more work, start at the medium cut compound step, or swirl remover and work your way to washing again. Then apply cleaner wax, then regular wax of your choice.
Old Jun 24, 2011 | 10:57 AM
808z28camaro's Avatar
Get any one of Adams polishes PC kits and you will NOT be disappointed!!! watch the vids. fool proof, good value, OUTSTANDING results. BEST systems available. Best proucts available. you would be a fool not to try Adams products.
Heres the link...
http://www.adamspolishes.com/c-14-po...polishing.aspx
Old Jun 24, 2011 | 03:13 PM
LilJayV10's Avatar
Thanks for the link man. That's exactly what I was looking for. I like the instructional videos.
Old Jun 24, 2011 | 03:49 PM
mrrman's Avatar
http://www.autogeek.net/po.html
another site to look at
Old Jun 24, 2011 | 06:06 PM
mshadow's Avatar
If you haven't ever wet sanded before I would go the porter cable route way to easy to mess stuff up wet sanding as a noob.
