Sealer only, no primer?
If it's straight and you're spraying a different color, prep per the sealers instructions and spray. Most of the time, you have a window where you can topcoat the sealer without any additional prep work. After a certain time span, you have to scuff or sand the sealer before topcoating. It depends on the brand of sealer.
If they body is wavy or you want to ensure it's very straight, I'd get a gallon of good 2K primer and prime and block the vehicle. You can then choose to seal it a different color afterward, to ensure a better base coverage. That's up to you.
