Cleaning/shaving engine bay questions?!?!
withouth having a welder what would be the easiest way to fill in the holes?
heres how it looks right now:
and this is kinda how i want it to look but with even less holes:
why ?
body filler cracks when flexed. if you use body filler over a hole it can corrode from the back and it will fall off in time. to get filler over a hole it needs to be thick, filler is not meant to be packed on thick. it will dry over time and crack the paint if it doesnt crack from flexing.
ive shaved a few engine bays. body filler can look ok for a short time, but in the long run you are screwing yourself. take like $200 and get to Harbor Freight to buy a welder and suppiles. its easy to use a mig welder.
