Spider Webbing
Old Jul 14, 2012 | 02:02 PM
xBrandonx's Avatar
Ok, well today, I got ALL of the spider webbing out. You can't see or feel them....
But now I'm left with 80 grit sanding marks, I followed it up with 180 and 320... it didn't take them away. So I tried 600.... 1000... nothing
Will the primer cover it up? How do I get rid of them? I will get pictures later.
Old Jul 14, 2012 | 04:30 PM
xBrandonx's Avatar
Here's pictures
http://imgur.com/a/yQPpt#0
Old Jul 14, 2012 | 04:47 PM
96z28_lt1's Avatar
i'm not in any way shape or form even really experience in painting but i believe you could try priming a spot a lottle bit then giving it a good wet sand and see how that turns out just in a spot if not try sanding it again with some finer sand paper
Old Jul 14, 2012 | 04:54 PM
xBrandonx's Avatar
I tried it with 600 and 1000 and all it did was hurt my arm haha, the scratches still remained.
Old Jul 15, 2012 | 07:49 PM
wysemunky's Avatar
Sand with 180 til the 80 grit marks are out, then with 320 til the 180 marks are gone. At that point you should be ready for epoxy primer and then you will see any imperfections that are left.
Old Jul 16, 2012 | 09:46 AM
Mishimoto's Avatar
If you use water based basecoat, you don't need the flex additive. Some of your real deep scratches may need a thin coat of glazing putty if you can't get them out with sanding.
Old Jul 16, 2012 | 04:39 PM
xBrandonx's Avatar
There not deep at all. I can't feel them with my finger, there just there. I think three coats of primer will cover them. As for the flex additive, this is the clear coat I'm using. Does it have it in it already?
http://www.automotivetouchup.com/auto_paint.asp
Ready To Spray Acrylic Lacquer Clearcoat
Use with spray gun and compressed air.
Automotive Clearcoat for use over basecoat color.
We carry two types of Clearcoat. Urethane Clearcoat and Acrylic Lacquer Clearcoat. Urethane clearcoat is a two component clearcoat which means 2 parts are mixed together. This product is more flexible, chemical resistant, has better gloss, and will last much longer than lacquer clearcoat. Once the 2 parts are mixed together the product cannot be reused later. Lacquer Clearcoat is a simpler product which is easy to use, easy to buff, extremely quick drying, and can be reused later. View Our Ready To Spray Paint Directions for more information on how to use our clearcoat products. Directions are included. Acrylic lacquer is much easier to apply and is an "air dry" clear. Breathing Respirators are required for these products.
Old Jul 19, 2012 | 05:19 PM
xBrandonx's Avatar
Got the paint, painting is Saturday.
Old Jul 27, 2012 | 07:57 PM
xBrandonx's Avatar
It's finally going in for paint tomorrow! I will post progress pictures.
Old Jul 29, 2012 | 09:53 AM
xBrandonx's Avatar
Got it painted... the bumper looks good, no cracking but... where I sanded to get rid of the spider webbing, you can see the marks. Everywhere I painted red, you can just see a little if you get all up on it. I'm picking it up this evening, how should I care for the paint? By that I mean, wet sanding, buffing, polishing, ect ect? Thanks
Old Jul 29, 2012 | 09:13 PM
xBrandonx's Avatar
Got it painted, looks great, few words of advice for the spider cracking.
SAND THE ENTIRE BUMPER DOWN EVENLY OR YOU WILL SEE THE MARKS WHERE YOU SANDED OUT THE CRACKS, ITS NOT BAD BUT STILL...
Heres the pictures!
Old Aug 10, 2012 | 08:41 PM
  #32
got milk??'s Avatar
For future reference a 2k high build primer after the 180 sanding would have leveled it out some. Then its all about hours upon hours of guide coat sanding and filling in the lowest spots with glaze. But it still looks good and Automotive Touchup sells a good product it will last for a long time!
Old Aug 11, 2012 | 10:25 PM
  #33
xBrandonx's Avatar
Thanks, yeah, I was hoping the primer I had would hide it but of course it didn't. You can only see it in certain lighting.
