water leak ideas?
Old May 6, 2012 | 11:23 AM
czechnuts's Avatar
Default water leak ideas?
Man were to start. For starters I live in the northwet! It rains a lot here. So keep gettin water in the cargo area. Like 4"'s and then also on the rear passenger floor board. It's a t-top to boot. Oh its a 94 formula. Any info would be helpful. I know I need to replace the window felts. But aside from that.....thanks
Old May 6, 2012 | 02:47 PM
Nathan C's Avatar
Make sure the car is parked on a level area. If you park with the front facing downward the drain channels will overflow and leak in the car. Also open the doors and make sure the windows are up all the way. If a window motor is starting to go bad it will not go all the way up unless you open the door sometimes. Hope this is a start.
Old May 6, 2012 | 05:04 PM
SparkyJJO's Avatar
Rear passenger footwell tends to be a leak from the rear of the t-top. Check the seals (make sure the rubber isn't folded over) and check the drain channel. Make sure it sits tight also when latched in place (the latch can be adjusted). On my old 98 the rubber wasn't sitting against the metal properly so water would flow through the little gap and inside the car if it rained hard enough. Instead of getting expensive new seals just for that I used a small bit of silicone to reseal that spot so the water could only flow down the drain. Worked perfectly.
Old May 8, 2012 | 09:19 AM
czechnuts's Avatar
Well it was nice out here yesterday and I took my tops off and didn't see anything out of the norm. I know my right side window motor is gettin weak and will need replaced. Plus since my felts were removed to avoid window damage. I have to push out on the window to ensure it closes completely. Until I replace them that is. Plus I have an idea of the rear. The seal around the bottom of the rear window is jacked. Thinkin that was from car washes. Is the a plug for the water?
