Hood repair question ??
Old Sep 10, 2012 | 07:53 AM
derekatnip45's Avatar
Default Hood repair question ??
Ok I have a factory camaro hood that's metal and long story short I've got a pretty good sized gauldge in it what can I use to fill the hole ? Will bondo work? Or is there something better ?
Old Sep 10, 2012 | 05:05 PM
jlcustomz's Avatar
If trying to fill a dent without popping any of it back out or any other of what may be termed proper repair methods, I'd use USC or Evercoat all metal filler for the worst of it &finish it & the surrounding area off with a smoother filler like evercoat metal glaze. Metal glaze will stick to clean & scuffed paint, all metal fiiler requires sanding down to bare metal to stick. Keep in mind that a deep dent will usually raise the height of the area immediately surrounding it Which requires skill to flatten it back down or filler for a longer ways away from it to hide the raised area.
Old Sep 10, 2012 | 08:36 PM
It's not really a dent it's more of a like a gash i could maybe beat it from the under side to make it a little more flush
Old Sep 11, 2012 | 05:17 PM
jlcustomz's Avatar
If you can access the bottom of that area, hammering it back up would difinitely help. Go at it carefully & if you don't have bodywork tools, holding a block of wood on the topside of the area as a dolly will help.
Old Sep 12, 2012 | 09:16 AM
Ok thanks again,
Derek
