drivers door hinge replacement
Old Oct 29, 2012 | 12:48 PM
daturbosix's Avatar
Restricted User
Default drivers door hinge replacement
anyone have a "how-to" writeup on the topic?
ive heard its really easy if you remove the front fender, but im trying to avoid that.
Old Oct 29, 2012 | 02:09 PM
HAte's Avatar
no you can pop the bolts out of the door first and either set the door down or you can take the door panel off then unplug all the wiring out of the door and remove the door completly but it is possible to do it without doing it the wiring way,.,,,just know the doors kinda heavy
door bolts first then you can take them off the A pillar
Old Oct 29, 2012 | 07:04 PM
Spartan7's Avatar
It's easier if you take off the fender. You're going to have to align it to the door anyway. Not to mention adjusting the hinges would be a PITA with the fender in the way.
Old Nov 3, 2012 | 11:18 AM
scj's Avatar
scj
Pull the fender liner and do it from inside the fender. Remove one of the hinges at a time with the door closed, then replace one, and remove and replace the other. So the door doesn't go anywhere while you're changing it.
