How to remove rear bumper cover
Old Dec 16, 2012 | 08:39 AM
30bandit99's Avatar
Default How to remove rear bumper cover
I tried searching but I didn't have any luck. Stuck half way, thought I got all the mounting points removed, but the bumper is still attached the the rear quarter panel and I'm not sure how to remove it from there.
So far I've removed:
-rear tail lights
-push pins on top of the cover (under the lights)
-screws in the wheel wells
-push pins under the bumper, 2 behind the licence plate, 2 under the exhaust outlets
I tried looking for how the bumper mounts to the rear quarter lying under the car, but it almost looks like rivets are? I know this can't be haha but what am I missing here? When I was searching I found it wasn't hard to remove the rear cover, but now I'm stuck in a stand still. I tried searching google and the forum but no luck.
John
Old Dec 16, 2012 | 09:44 AM
30bandit99's Avatar
bumped
Old Dec 16, 2012 | 10:52 AM
67goatman455's Avatar
its been a while snce i took one off, i cant remember if those little screws in the fenderwell stay screwed in or you take em out.
anyways, you are missing some 10mm nuts to take off. where that little screw is, keep reaching behind the panel and there is one 10mm nut there.
then inside the car behind the carpet you have two more nuts to remove. one is against the side and one is on the tail panel.
Also, i dont know what you took off behind the license plate, but that wasn't necessary.
Old Dec 16, 2012 | 12:03 PM
30bandit99's Avatar
YESSSSS!!!!!!!! Thank you
