Trans Am Hatch Swap Problems. Help?
Old Apr 21, 2013 | 02:38 PM
ArticFormula's Avatar
Default Trans Am Hatch Swap Problems. Help?
Okay so I bought a T/A hatch a few months ago.
Since it finally warmed up here in Michigan I pulled out the car to put it on.
I've done a lot of research and everything went smoothly.
Until it was all bolted on.
As you can see in pictures, there is a 1 inch gap between the glass and the support beam (not sure what its called but you know)
The hatch lines up with the tail lights fine.
I'm not sure what year the hatch is off.
Any ideas?
Help is appreciated!
Thank you.
Attached Thumbnails Trans Am Hatch Swap Problems. Help?-photo-copy.jpg   Trans Am Hatch Swap Problems. Help?-photo-copy-2.jpg   Trans Am Hatch Swap Problems. Help?-photo-copy-3.31.15-pm.jpg   Trans Am Hatch Swap Problems. Help?-photo-copy-3-3.31.15-pm.jpg
Old Apr 21, 2013 | 09:33 PM
sjsingle1's Avatar
looks like the glass could be a little closer to the sail panel
Old Apr 22, 2013 | 04:41 PM
bump?
Old Apr 22, 2013 | 10:52 PM
wabmorgan's Avatar
Looks like you need to loosen the bolts to the hatch and push it a little closer to the sail panel.
