Sail panel triangle. How to remove?
Old Dec 10, 2013 | 09:11 PM
GarrettM's Avatar
Default Sail panel triangle. How to remove?
The little triangles infront of the sail panel. Mine are cracked and I found replacements from Hawks3rdgen. How do I remove those to replace them? Are the epoxied on or clipped or what?
Old Dec 10, 2013 | 11:18 PM
JOHNNY59's Avatar
its put on with the same adhesive that's used on the sail panel. I use a heat gun to soften the glue, then use a box cutter with long blade or putty knife to cut the adhesive.
Old Dec 10, 2013 | 11:32 PM
GarrettM's Avatar
Good stuff, Thanks.
Old Dec 11, 2013 | 06:56 PM
ctjohns's Avatar
mine were two sided taped over the whole back side, heat it up and pull em off
Old Dec 11, 2013 | 09:40 PM
johnp94's Avatar
Work from the bottom up. If you go in from the side you start prying off the fiberglass like I did on my first sail panel removal.
