Fender rolling issues HELP
Old Jul 23, 2014 | 06:06 PM
acuraguy81's Avatar
Default Fender rolling issues HELP
I have a 1999 Firehawk with 315/40/18 and they rub. I would like to roll the quarters but they are double thick and don't roll easy any tips please?
Old Jul 23, 2014 | 07:05 PM
ARLS1's Avatar
If you are using an actual rolling jig all I can say is take it slow and good luck. If you crack paint right along the edge you can sand it down with 2000g and apply touch up paint to the edge to avoid repainting or rust.
Old Jul 24, 2014 | 09:17 AM
burgundybullet's Avatar
Try to either heat it up somehow without wrecking the paint or leave it outside in the heat to help make it slightly more workable. It is also beneficial to the paint because it has less chance of cracking since the heat with allow the paint to flex easier.
Old Jul 27, 2014 | 10:56 AM
acuraguy81's Avatar
any more comments of experience rolling an f-ody quarter they are so thick.
Old Aug 14, 2014 | 05:34 PM
yodas little brother's Avatar
use a baseball bat(aluminum) on the inside,in wont flare out the quarter but it will flip that inside lip up so you wont have issues.i used a hammer first then went to the bat.
Old Aug 14, 2014 | 08:35 PM
LPE 403's Avatar
Use the right tools....Fender Roller. You can rent one from 69TA on this site.
I have my own. Works great with some patience. Have to heat the paint on the flange with a heat gun to avoid cracking.
Old Aug 16, 2014 | 12:36 AM
EFoxwell's Avatar
^ This. The heat gun is a big help.
