Brush on chassis epoxy?
Old Feb 12, 2017 | 02:01 AM
HappySalesman's Avatar
Default Brush on chassis epoxy?
Since I've got my motor out, I plan on cleaning and painting the front suspension. I was planning on using Summit's Chassis Shield epoxy. I don't have access to a compressor or spray gun, so I thought I would brush it on.
Has anyone done this? How did the finish turn out?
Old Feb 12, 2017 | 09:04 AM
Majestic9C1's Avatar
https://www.kbs-coatings.com/
Old Feb 12, 2017 | 06:40 PM
wan2run's Avatar
Check out POR-15 semi gloss black and chassis top coat. Used them on my C3 frame during the resto and I'm extremely happy with it.
Old Feb 17, 2017 | 02:14 AM
So for these products (Chassis Shield, KBS, Por-15) would I need to take the front suspension all the way down to bare metal? The only corrosion is on the top of the upper control arms (where the nut for the strut is) so can I just scuff the existing paint or would stripping it be better?
Old Feb 17, 2017 | 09:35 AM
with KBS you can paint right over the rust ( a light scuff helps)
