Painting lid
Old Jun 16, 2017 | 03:48 AM
HappySalesman's Avatar
Default Painting lid
Just got an FTP lid and I want to smooth and paint it to get rid of the cheap ABS texture. When sanding, should I sand all the way down through the texture or just knock it down a bit? Don't want to thin the plastic out too much.
And what fillers are recommended for plastic like this?
Thanks!
Old Jun 16, 2017 | 01:19 PM
blackbyrd's Avatar
Id rough it up a bit then go back with a highbuild primer use that to get your smoothing down, May want to put some tape where the tubing slips over the snout for the TB side so you dont add to much and make it difficult to slip the coupler over
Old Jun 16, 2017 | 11:42 PM
Ah okay, thanks!
Old Jun 21, 2017 | 10:14 AM
Aaron23's Avatar
Default Plastic Painting
Painting plastic entails different prep work than steel. You need to sand with red or gray scuff pad(Scotch-brite). Clean with IPA(isopropyl alcohol). Spray with adhesion promoter first, then apply primer and paint. Follow promoter directions on can.
