sand blasting engine bay?
https://www.harborfreight.com/21-oz-...gun-95793.html
I have spot sandblasted... it makes a mess, sand does get into everything, and if you don't properly prep/prime you will make things worse.
Edit: You can order it online ( I haven't used this company)
http://www.66autocolor.com/Auto-Touc...mixedpaint.htm
Back when I swapped my engine I used POR-15 Chassis Coat. I cleaned the rust areas with a wire brush in my drill along with a Dremel tool for the real tight spots. I wouldn't use spray paint unless it was a satin black epoxy as a top coat over POR-15 which I have done and still looks good after over five years. I like finishes which are almost impervious to oil and solvents and spray enamels don't do it.
https://www.por15.com/Rust-Preventive-Coating_c_11.html
but this is what i would spray over top
https://www.por15.com/TOP-COAT_p_102.html
since this isn't show quality is there anything wrong with this plan?
remove front fascia, and all those other pieces that unbolt. rough up everything, wire wheel any rust spots. engine bay and frame rails use rust preventative coating, since this can easily be brushed on in these areas. then spray with the top coat.
as far as the rad support area, no need to brush on the rust preventative, just spray with the top coat after scuffing and cleaning ....
On a Feiro we painted the engine cradle with POR-15 and sprayed with high heat VHT and it has been 5 years at it still looks the same. We like that high heat paint cause the stuff dries almost instantly and looks and durability seem to be similar.
