how to fix fender alignment
The bulge is a little lower than yours but almost exactly there. I've already fixed the lower tabs and it's lined up great towards the bottom. Mine bows out a bit a little lower than yours did and the curve does not match the driver door. I can see a the bolt under the cowl and another one about midway down the inside the door, looks like a pain to get at. I don't mind turning wrenches but I've always had **** luck with body panels. Do I just loosen the bolts and push the fender in then retighten?
