Regulator rivets
Old Aug 24, 2019 | 12:55 AM
Lt1slowerbird's Avatar
Default Regulator rivets
My driver side window started having fits. Pulled apart and noticed when window is ran the regulator rivets are moving back and forth. It’s Starting to tear the inner door. My question is can I drill these rivets out 1 at a time and replace with a bolt and a large fender washer? Like drill 1 and replace with bolt and big washer then drill another? Or will even that still throw my alignment all out of whack? At the moment I just gooped a whole bunch of jb weld I had laying around on the rivets to maybe help strengthen the surrounding fiberglass. Also going to try and figure out where the Express down module is for the window and disable that. I believe that is the root cause of this issue
