Removed emblems and this happened.
Old Oct 28, 2020 | 02:39 PM
SCLT1's Avatar
Default Removed emblems and this happened.
Installed my emblems back in 1997 and others cleaned up with a clay bar but this side refuses too. I don’t have a buffer so would wet sanding with 1000 grit work? It’s rock solid stuff on here even tried some heat and nothing. Sorry for the blurry picture but sun was shining.
Old Oct 28, 2020 | 03:53 PM
Kjduvall's Avatar
I may get flammed for this by the body guys that do this for a living, but old tuff adhesive usually will get much more (soft/workable) with wd40 sprayed on it. Controlled though, saturate area heavy and keep surrounded area clean. It'll loosen up and give you easier removal. Be patient it may take several soakings. Then buff out panel when done.
Old Oct 28, 2020 | 03:59 PM
SCLT1's Avatar
Won’t that hurt the paint though?
Old Oct 29, 2020 | 03:14 AM
Kjduvall's Avatar
It's never hurt my paint, I've used it to loosen up adhesive on my side molding, formula badges, and many other things too. Also works good to get rubber to come loose on rear quarters after a big smokey burn out. But you have to wax the panel out good after you get it all off.
Old Oct 29, 2020 | 04:52 AM
98CayenneT/A's Avatar
I would use a 3m stripe off wheel meant to be used with a drill. It's a rubber wheel that safely removes adhesive.
1000 grit is WAY to aggressive for factory clear coat which is only around 50 - 75 microns thick ( .0025" )
Here is the wheel
https://www.oreillyauto.com/detail/b.../07498/4461990
Old Oct 29, 2020 | 05:07 AM
SCLT1's Avatar
Okay thanks next time I’m in town will check it out!
