Rear window vibrates when closing hatch
Old Jan 1, 2021 | 10:40 PM
JimMueller's Avatar
Default Rear window vibrates when closing hatch
I noticed today that when I closed my rear hatch there was an unusual noise. I repeated it and it appears that the rear window, along with the 4-piece trim, is vibrating when the hatch latches. The car was last rear-ended years ago and it wasn't very noticeable so I didn't get it repaired. The latch is pushed in a bit so that I cannot use the key to operate the lock, but the remote operates the lock just fine. As a result, I've needed to exert a bit more force when closing the hatch to get it to latch. Is this something I need to worry about and if yes what type of repair may be needed?
Old Jan 3, 2021 | 08:43 PM
Nathan C's Avatar
If the hatch is loose, I imagine water will eventually leak inside.
Old Jan 8, 2021 | 12:03 PM
JimMueller's Avatar
I called Safelite and AutoGlassOnly, both said they could not repair the urethane without replacing the entire glass, then told me to call a body shop. Called a reputable local body shop and they told me just the opposite that a glass specialist needed to handle that. Luckily they gave me their glass contact and I'm waiting for a text back on a quote. He needs to replace the urethane and molding strip in the same job, and upon a quick initial search he was having trouble locating the parts.
