How much paint and clear do I need?
Old Apr 13, 2024 | 07:57 PM
DougEFresh's Avatar
Default How much paint and clear do I need?
I have a 01 Sierra ex cab and I知 wondering how much paint I値l need to do a full color change. I知 not worried too much about the inside of the bed because I知 probably going to rhino line it. I was thinking 1 gallon of base and 2-3 quarts of top coat then a gallon of clear. Any help or suggestions would be much appreciated. Thanks guys.
Old Apr 13, 2024 | 08:47 PM
Doug G's Avatar
When my Camaro was painted (jams and all) I was told 2 gallons paint and 1 clear.
I guess it will really come down to color it is now, and color it's going.(some colors cover fasterandbetter than others)
Old Apr 14, 2024 | 02:05 AM
DougEFresh's Avatar
I think I found the color I want. It痴 from a company called Tropical Glitz and the color is Cognac Delight. I知 planning on doing that color over a white or grey base.
Old Apr 14, 2024 | 07:29 AM
Doug G's Avatar
So, is this a translucent (like a Candy) ?
Old Apr 14, 2024 | 07:56 AM
Ls7colorado's Avatar
You will need a gallon of sealer, and a gallon on paint, and a gallon of clear.
Most paints after mixing reducer will make about 1.5 gallons
Most clear coats will make 1.25 gallons some will make 1.5 gallons after mixing in hardener.
I usually do 1 coat of sealer, 2 coats of paint on roof, and 2 or 3 coats of paint on the rest of the body and always have some left over.
Then I will do 2 light coats of clear followed up with a nice glossy wet coat.
Old Apr 14, 2024 | 09:27 AM
DougEFresh's Avatar
It says you can mix it to be a semi-translucent.
Old Apr 14, 2024 | 09:30 AM
DougEFresh's Avatar
I was also debating on this color but over a black base.
Old Apr 14, 2024 | 02:44 PM
Doug G's Avatar
Damn that looks good.
Old Apr 14, 2024 | 11:25 PM
DougEFresh's Avatar
A friend of mine suggested maybe doing my truck that color and the rims the copper.
Old Apr 18, 2024 | 05:12 PM
Doug G's Avatar
I'd have to see that in photoshop first...I was thinking black or color match ?
Old Apr 19, 2024 | 08:55 AM
DougEFresh's Avatar
I think which ever color I choose I知 going with chrome Iroc痴. Probably 22痴
