Rust Problem
Old Dec 9, 2006 | 04:40 PM
irnbru83's Avatar
Default Rust Problem
Got some rust forming on the hinge on the driver's side door. Was wondering what the best way to combat this problem would be?
Sand as much of the crap off as possible without ruining the rest of the paint, then use a rust remover, then use some kind of a sealant?
I thought this would be a fairly common problem, but I couldn't find anything with Search.
Old Dec 9, 2006 | 05:19 PM
VSGLS1's Avatar
Post pics of exactly where on the hinge it is.
Old Dec 9, 2006 | 05:30 PM
30thanniv's Avatar
If it is on the actual hinge itself I would try and clean it up as best as possible and touch it up. No sense in going nuts with it. It is a thick piece of metal that will not rust and fall apart. If it does, you have bigger problems then a hinge.
Old Dec 10, 2006 | 12:17 AM
irnbru83's Avatar
I'll get a pic in the morning, but yes, I'm talking about the surfaces of the hinge that rub together.
