Taking Your Headlights Out
Thanks,
David
Disconnect the bulbs by the harness.
Turn the bulbs towards the middle of the car and they should just slide out.
Un bolt the 2 10mm bolts.
Slide the headlight toward the inside of the car that way the tab clears the hole, and lift it on out.
It's a lot easier than you think. Most of it is self explanatory once you see it. Let me know if you need more specific details.
I might also suggest leaving the headlights in the oven for 25 minutes not 20
When I did mine some of the silicone cracked parts of the headlight off at 20min. So i stuck it in there for a little longer and it came off like butter.
