Paint Questions
Old Mar 18, 2007 | 02:24 PM
Novacaine's Avatar
Default Paint Questions
Recently I started painting our 52 Hudson Hornet with a royal blue type color and after getting all the old paint off (pain in the ***) primering it and sanding it smooth then applied the basecoat and clearcoat and it came out with a tad bit of orange peel so I sanded down a bit with 2500 to make shure that it wouldnt scar it to bad, buffed it out then it looked fine under normal flourescent lights but I pulled it out into the sun the next day and it looked like it had swirls in the paint. Any ideas on what caused this our how to make it go away?
Old Mar 18, 2007 | 04:51 PM
transmaro93's Avatar
well if its just really fine buffing swirls... id use a swirl remover with the buffer and the proper buffing pad... then id hand glaze it by hand just to make sure...but thats all i got... if they are straight looking scratches then you didnt buff enough.... what did you do to buff it?
Old Mar 18, 2007 | 04:59 PM
Pheonix's Avatar
Sometimes i get really bad orange peel and i have sanded with 1500 and i use 3M 5936 extra cut buffing compound with a polishing pad and it takes every scratch out. You might need to order that compound because they dont sell it no more unless you ask for it, it was replaced with 6060, but you can still order it.
