Paint/Nightshade Removal....HELP!!
Old May 18, 2007 | 05:56 PM
my01ws6's Avatar
Default Paint/Nightshade Removal....HELP!!
Ok well I sprayed all my side markers and my tailights....all the turn signals turned out GREAT!!! BUT the tailights are all blotchy....light in some areas...dark in other....how can I strip off ALL the nightshade and start over??
Thanks for ANY help!!!
Old May 18, 2007 | 06:26 PM
mycamaroSS's Avatar
i dont think you can, my riend tried using rubbing alcohol, water, etc and he couldnt get it of. He just had to replace the taillights
Old May 18, 2007 | 10:02 PM
my01ws6's Avatar
anyone else? will laquer thinner take it off? or do I have to sand it down all the way?
Old May 19, 2007 | 03:37 AM
sercastiK's Avatar
I think id wetsand em with 600 or 100 than reshoot em, laquer thinner will **** them up.
Old May 19, 2007 | 07:21 AM
jester1614's Avatar
i personally have used laquer thinner and then an putty knife to scrape the nightshades off. after you put the thinner on it will soften the paint. you can allways wetsand it.
when i used the laquer the paint was still relatively wet. I am unsure if that makes a difference.
i would recommend wet sandin it.
Old May 19, 2007 | 09:32 AM
GET_SOM's Avatar
rubbing alcohol didn't work for me and laquer thinner will definitely f*ck them up (I know from my buddies attempt).. I say +1 for wetsanding em. Have you tried to even out the vht? Depending on how dark your nightshade is you could buy blackouts.. just my .02 cents
Old May 19, 2007 | 02:30 PM
my01ws6's Avatar
to black to put anything over them....
Old May 19, 2007 | 04:19 PM
J2DSCO's Avatar
You're probably going to have to sand them back down to how they were before you sprayed them. Did you make sure to wet sand the lights really good before you sprayed the first coat? Make sure you spray them really even and don't try to fix something by spraying it more in one area because most likely you'll end up with weird build up spots.
Old May 19, 2007 | 09:15 PM
my01ws6's Avatar
well a can I got was screwed up.....while I was spraying it would pause...
