Right headlight "higher" than the left
Old May 21, 2007 | 01:20 AM
Hawk312's Avatar
Default Right headlight "higher" than the left
I originally posted this in the General Maintenance board, but now I think it might be more appropriate here.
I just did the headlight fix by Brent Franker (http://www.bfranker.badz28.com/headlightfix/index.htm) on a `98 Trans Am. Now, whenever the lights are up, the right headlight, which needed the fix, is not up as high as it used to be. I know because I can no longer see the top of the right headlight from the driver`s seat when the lights are up, and the light beam itself is pointing down. This wasnt a problem before the fix. The headlight seems to operate just fine otherwise. I tried manually cranking the right headlight up hoping it would be up higher when it is up, but apparently it self-adjusts. Any ideas?
Old May 23, 2007 | 07:26 AM
Hawk312's Avatar
Anyone?
Old May 29, 2007 | 08:14 AM
Hawk312's Avatar
Still having trouble with this guys. Anyone have an idea? How do you adjust these things??
