Bumper/Hood Gap :(
I'm not sure if the bumper was cut or what but it appears to not go as far as it needs to / should be. If you look at the pictures the gap is pretty obvious and I am looking for a way to fix this. Yes, I know that the other gaps are not correct yet, but this is not a problem which can be fixed via aligning of the pieces.
I am hoping to avoid fabricating a piece to make the bumper or hood fit closer and hoping that there is a piece which can go in there which will look good but am somewhat resigned to the first option.
Would it be possible to create a fiberglass piece that would be attached to the bumper bar and connect the two pieces and look decent with just adding another crack?
