Fender Removal Help!!! Please
Old Nov 6, 2007 | 09:43 PM
1fastz's Avatar
Default Fender Removal Help!!! Please
Ive removed every single bolt except for the last three bolts by the headlights. They are the bolts that the only way to take them off is by unscrewing the nut on them (which is on the bottom) becuase you cant unscew the bolt itselt becuase its head is round/flat. I dont know how to get to them! Do i get to them through the bottom? need help asap!!!!!
Old Nov 6, 2007 | 10:12 PM
SparkyJJO's Avatar
It was easy for me to get to mine when I was trying to straighten out the bent brackets to put my headlight back where it belonged since I have a hole in my fender and bumper, but I'm not sure on how to get to it with the fender in one piece. I'd like to know this as well for when I replace my busted fender.
Old Nov 6, 2007 | 10:18 PM
z06 mike's Avatar
remove the headlight and you can reach right in.
Old Nov 10, 2007 | 01:43 AM
00FastSS's Avatar
The "bolts" you are speaking of are actually resistance welded studs. The only way to loosen the fender from the bumper cover is to remove the nuts that are attached from the bottom. That may require taking off the inner fender. Hope this helps.
