Gas cap door Removal & installation
Old Nov 25, 2007 | 12:47 PM
ORedRoc4's Avatar
Default Gas cap door Removal & installation
How the hell do you remove this door? I have some body damage there and am starting to get it all prepped, well where the car was hit the door was also damaged. Am i going to have to cut the swing arm and weld in a new door with arm? or does it bolt in on the inside of the QP? Thanks in advance..
-justin
Old Nov 25, 2007 | 02:29 PM
Pheonix's Avatar
It has four rivets you have to drill out and then when you go back you just put four back.
Old Nov 25, 2007 | 05:14 PM
ORedRoc4's Avatar
where are they at? On the door or on the inside of the QP?
-justin
Old Nov 25, 2007 | 08:07 PM
Pheonix's Avatar
the should be right where it henges open they are on the out side quarter panel and it is also glued from the inside but that will come off when you take the four rivets off. You should be able to see them when you open the gas lid. Can you post pic?
Old Nov 26, 2007 | 01:00 PM
ORedRoc4's Avatar
I can post a pic, but it may be a bit, im working this fucked up work schedule, so my car time is very limited...
-justin
