Can I fix this myself?
Old Jan 4, 2008 | 07:58 PM
newton's Avatar
Default Can I fix this myself?
Someone hit me and ran. The car is old and the overall paint on the car is faded anyways, so I just want to perform a quick fix until I can one day get the entire car repainted.
Attached Thumbnails Can I fix this myself?-img_7150.jpg   Can I fix this myself?-img_7151.jpg   Can I fix this myself?-img_7152.jpg
Old Jan 4, 2008 | 08:31 PM
EHat911's Avatar
its hard to tell from the pictures but is the panel cracked in any way?
Old Jan 4, 2008 | 09:22 PM
z2fast8's Avatar
do u have any bodywork skills? u should know if u can fix it or not if u do.
Old Jan 4, 2008 | 09:41 PM
newton's Avatar
Yes, it's cracked.
No I don't have any experience with bodywork.
Old Jan 4, 2008 | 09:46 PM
calz28's Avatar
if you are gonna get it repainted buy a used fender, i got one for the right side for $120
Old Jan 4, 2008 | 09:48 PM
LS1BLKSS's Avatar
Banned Village Idiot
i think you should be able to fix it... it looks like its only the fender... i would remove it and see if you can pop back in that hit... i don't know if the fenders are fiberglass??? if they are that dent should pop right into place... then you should sand it and paint it or just primer it!
Old Jan 4, 2008 | 09:53 PM
spookyz28's Avatar
If you want to do it right, get a new fender
calz28's Avatar
i tried on mine, it's plastic
Old Jan 4, 2008 | 09:54 PM
LS1BLKSS's Avatar
^^^ then it should just pop right out
LS1BLKSS's Avatar
*** if its not cracked!***
Old Jan 4, 2008 | 09:55 PM
calz28's Avatar
not really, his is cracked like mine was
Old Jan 4, 2008 | 09:57 PM
LS1BLKSS's Avatar
that sux now he needs another fender unless he fixes that crack some how
Old Jan 4, 2008 | 10:29 PM
transambandit's Avatar
for a front panel like that get a new panel, they are extremely easy to swap out and chances are you could find one in black easy.
Old Jan 5, 2008 | 02:18 AM
1FastBrick's Avatar
Replace the panel!!! If you attempt to fix the crack, the repair will shrink later on down the road and you will see it under the paint. What it is made of and the plastic repair on the market will Expand and contract at diffrent rates.
Stick with an origanal GM fender for fit and finish. If you can find a good used one, just do that... You should have no trouble finding a black one if your patient. contact local wrecking yards near you. Or go to the self serve ones and look around.
Best of luck...
Old Jan 5, 2008 | 02:21 AM
YellowB4Z's Avatar
Black was one of the most popular colors on 98+ camaros. Find yourself another black fender. Fixing it would be more work than its worth. Good luck.
Jeremy
Old Jan 5, 2008 | 08:35 PM
EHat911's Avatar
if it's cracked then it's going to be extremely hard to fix to where you wont see it so your better off just trying to find a fender from someone one and then getting it painted or repainted if you go with a used one.. better yet maybe you can find one thats already black
Old Jan 5, 2008 | 08:38 PM
EHat911's Avatar
but whatever you do do not but an aftermarket fender they never ever fit right and look like **** i know from personal experence of my old car and working at a body shop i see it all the time trust me if you car about your car and are going to replace the fender get a GM fender only!
Old Jan 5, 2008 | 08:45 PM
slammed1500's Avatar
get a new fender
Old Jan 5, 2008 | 09:15 PM
GunshotZ28's Avatar
First things first.. Get a new fender and take it to a local body shop and have them prep it up and spray it for you. Don't waste your time trying to fix it. I work at a body shop and we replace stuff like this all the time. Once that's done, pick it up and take it back home or where ever your car is at and put it back on. Oh, for the z28 emblem and that body molding, just buy some 3m double sided tape and stick it on the back of those two and they will stick onto the fender.
Old Jan 6, 2008 | 02:34 PM
EHat911's Avatar
^ agreed the car is black so they will not have to blend anything to make it match correctly and if they tell you they do walk out and take it to the next body shop haha
