Fixing Rust hole
Old Jan 10, 2008 | 05:26 PM
BizZzatch350's Avatar
Moderator
Default Fixing Rust hole
Whats the best way to fix this and how much do y'all think it would cost?
Old Jan 10, 2008 | 05:46 PM
Ziggy93's Avatar
The "BEST" way to fix it is to cut it out and replace it with new metal. You could grind it, fiberglass it, fill it, and paint it, but eventually you'll have a bigger mess than you've got now.
Old Jan 10, 2008 | 09:20 PM
redramair98's Avatar
cut it out and weld a patch, you could even cut it across taht the factory seam and seam seal it and hide the rest of it with filler
Old Jan 11, 2008 | 01:14 AM
x2jesse1x's Avatar
Looks like you the quarterpanel is dented so it might not be a bad idea to just replace the whole thing instead of patch it. Prob cost like 500-750 to do it right. Or im sure u could cut it and patch it with new metal for alot cheaper
Old Jan 11, 2008 | 01:31 PM
Moderator
The Panel isn't dented, heres a pic of it
Old Jan 11, 2008 | 04:14 PM
SparkyJJO's Avatar
You're just seeing the shadow of him taking the pic
