Free hand on top of paint.
The key i just to keep a steady hand, and steady distance with you're hand from what you're painting on. If you keep it steady, and the brush the same distance away, the line will be the same width. You'll be fine with just a fine brush. I never had much luck trying to stripe with automotive paints. The paint most stripers use is called One-Shot. Its the right consitancy to lay an even line, comes in many colors, and it dries fairly fast. O and practice what you're doing first on an old plastic license plate, or something of about the same texture as the intake. If you want it centered, i'd measure it out too. I'd clear it first, and like Beyond Static said you could wipe it off with thinner if you mess up, then clear it again. Should be pretty cool when you're done!
